Hello,
I probably sound like an echo to you all in here but I appreciate any guidance you can offer. Recently assembled my first machine with parts ordered from Newegg. The first time I fired it up all the fans were running including the HSF but I got a "CPU Over Temperature Error" so I shut it down immediately and did some investigation. I suspected that while installing the stock HSF I may have mucked up the compound by seating and then reseating it to more cleanly run the fan cable to the connector. Ok, first lesson learned...
Next I started to question the stock Intel HSF and decided even if it does work acceptably when properly installed it couldn't hurt to get a better performing device to protect my CPU. So I ordered the Arctic Cooling 13 and the Arctic Clean kit to remove the old compound and purify the surface. Last night I cleaned off the old thermal compound and installed the new cooler using the pre-applied thermal pad and when I fired the box up it was giving me a "CPU Fan Error." The cooler fan was running and I did leave the machine on briefly to look around the EFI BIOS and it showed the 3 case fans active and the CPU Fan entry looked as if it hadn't detected one... The temperature already was already near 100 and going up though I restarted once and it was not giving the CPU Over Temp error, still just the cpu fan error.
Below are my build specs. I assume my next step is to remove the cooler, clean the thermal pad and re-apply compound myself. Any other thoughts, ideas or suggestions before I proceed? Thanks in advance!
MB ASUS|P8Z68-V PRO Z68 LGA1155 R
CPU INTEL|CORE I5 2500K 3.3G 6M R
VGA MSI|R5770 HAWK 1G RT
PSU CORSAIR|650W CMPSU-650TXV2 R
CASE LIANLI|PC-K7B RT
