My First Build. I have some questions. Help??!?
lordxarus
128
I am building a new PC I need a monitor for 150 or less I also need a PSU. Also do prices go down during Cyber Monday?
Specs:
CPU: Intel Core i7-3770K Quad-Core Processor 3.5 GHz 8 MB Cache LGA 1155 - BX80637I73770K (319.99 @ Amazon)
http://pcpartpicker.com/part/intel-cpu-bx80637i73770k
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.98 @ NCIX US)
http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2
Motherboard: Asus P8Z77-V LX ATX LGA1155 Motherboard ($119.98 @ NCIX US)
http://pcpartpicker.com/part/asus-motherboard-p8z77vlx
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory ($44.99 @ Newegg)
http://pcpartpicker.com/part/corsair-memory-cmz16gx3m2a1600c10
Storage: http://pcpartpicker.com/part/seagate-internal-hard-drive-st1000dm003
Video Card: http://pcpartpicker.com/part/gigabyte-video-card-gvr797to3gd $406 @ ncix
Case: NZXT Phantom 410 (Black/Orange) ATX Mid Tower Case ($84.98 @ Newegg)
http://pcpartpicker.com/part/nzxt-case-caph410b3
Power Supply: XFX 550W ATX12V / EPS12V Power Supply ($59.99 @ NCIX US)
http://www.newegg.com/Product/Prod [...] r-Supplies
PC Power&Cooling Silencer MKlll.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233246
First off guys I am a programmer I will be compiling things as big as a linux kernal really I just want one monitor that is pretty solid and a PSU that will not choke my components. My budget is 1400.
-pretty hard to break a CPU. just dont touch the bottom
-pretty easy to bend pins on the socket so dont touch that either.
no. all you have to do is put a pea sized blob of thermal paste in the middle of the CPU and the goop will spread out from the pressure from the heatsink. too much thermal paste will have negative effects on your temps
No don't put it under the heatspreader. Just put it on top where the heatsink will touch. Some extreme people pry off the heatspreader and put better paste under there. It is for min/maxers, not really for someone who will only slightly overclock.
