My first build please help would this work?
pivotfreaker
27
I wanna build this PC. This will be my first PC that I ever built so I am not an expert. I need so advice please.
Would this system boot-up / work without any problems?
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119225
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136533
Rosewill LIGHTNING Series LIGHTNING-1000 1000W ATX12V/EPS12V 80 PLUS GOLD Certified Modular Active-PFC Power Supply
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817182239
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115070
LITE-ON 24X DVD Writer Black SATA Model iHAS-324-98B
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827106334
TWO OF THESE (My motherboard is SLI Compatible) ->>> EVGA 012-P3-1571-KR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130613
Mushkin Enhanced Radioactive 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model 997005
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820226219
ASUS P8P67 PRO (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131703
Noctua NH-D14 120mm & 140mm SSO CPU Cooler
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835608018
Windows 7 64-bit
Switch to an Asus z68 board in case you want to throw in a cheap 40 GB ssd in later for caching with Intel S.R.T.
Don't get a Rosewill PSU. A corsair AX850 would be appropriate for this build. Or the non-modular corsair tx850. Rosewill just isn't known for making non-crappy PSUs.
