My first external build won't boot up ): Help!!
TheScarecrow97
355
So I've been following along with a video as I do this. I've got the cpu power, cpu fan, pci express, main motherboard power, all hooked up. I have turned on the power supply, and made sure the electrical socket is working and not dead. But when I use a flat tip screw driver to short the two pins labeled "pwrbtn", nothing happens. My motherboard (asrock 970 extreme3) did not come with the audio header so I don't get any post beep. No fans turn on or anything. Nothing appears on my screen. Absolutely no response. I have also tried plugging in the cord labeled "PowerSw" from the case into the "pwrbtn" pins. I then pressed the power button and still nothing. Help please! D:
The psu fan did not turn on, but I did turn on the switch located on the power supply.
