Hello! 😉 After long research I made it!
As I have mentioned before in my previous thread, I never build a PC in my life. This is my first build!
Here it is :
Also, I have a question, it is the best build I can get for my money?
Thanks for your help in advance!
Here it is :
- Motherboard - ASUS ROG STRIX B550-F GAMING
- CPU - AMD Ryzen 5 3600X
- Cooler - AMD Box Cooler
- GPU - ASUS RX460 (My old GPU. I decided not to sell it and use it until prices will go back to normal.)
- RAM - Patriot DDR4 8Gb 3200MHz pc-25600 Viper Steel (2x)
- Power Supply - AEROCOOL VX PLUS 650W
- SSD - WD Blue SN550 WDS500G2B0C 500GB
- Case - Lian Li LANCOOL II MESH Performance
- Approximate Purchase Date: This week.
- Budget Range: $800 - 900.
- System Usage from Most to Least Important: Game development/Rendering.
- Are you buying a monitor: No.
- Parts Preferences: The best of the best.
- Your Monitor Resolution: 1920x1080.
- Additional Comments: I'm a game developer, not a gamer 😉 I need to build a PC to make games, not to play them.
- And Most Importantly, Why Are You Upgrading: My old PC is obsolete, and I need to upgrade it.
