Hi Guys,
I have
i5 2500k 3.3 Ghz which I plan to overclock a high as I can
XFX HD 6950 and I`m getting another one soon
Case from NZXT Lexa S
and I want to know what WC kit should I get. I`m competely new to this kind a thing, so I don`t think that building my own will be an option. I`m looking at Corsair H100 as a budget one, but is it powerfull enough to handle OC cpu and two gpu`s? Also i found that Swiftech H2O-X20 "Edge" has good reviews, but it is a lot more expensive. is it really worth that money?
http://www.corsair.com/cpu-cooling-kits/hydro-series-water-cooling-cpu-cooler/hydro-series-h100-extreme-performance-liquid-cpu-cooler.html
http://www.overclock.co.uk/product/Swiftech-H20-220-Edge-Liquid-Cooling-Kit-External-Radiator-LGA1366--1156--1155--775_34821.html
Some general questions- how often do i have changhe liquid? Is it expensive? How noisy these systems and reliable are?
It`s quite a choice on these things and they all look pretty much the same to me
Thank You
I have
Thank You
