[SOLVED] My Gt 1030's fan is making noise!
iamyash03
21
I bought a gigabyte GT 1030 which was working good till now. But now its making noise and fan is not spinning properly. Please help!!
I cleaned the dist but the fan is making noise i . I tried to reapply the fan but it didn't work .then i tried to reseat the gpu many times in different positions but now i am left all alone asking for help. 🙁
Any help would be really appreciated
If the fan is defective this may be something only Gigabyte can fix and this would be the route I'd go as that card should still be under warranty.
Defective fan possibly?
If there is quite a bit of dust buildup then you'll want to remove it immediately as that could damage the fan and possibly make the GPU run a bit hotter then it should be.
Reactions: iamyash03
