[SOLVED] My Monitor Shows No Signal When Connected Yo Gpu, And Gpu isn't showing even in Device Manager.
May 5, 2020
My Gpu is Acting like this since I Changed my Windows 10 to 7 .
Then I started trying fix
But, Everything was waste of Time Any Suggestions
I Tried reseating, Cleaning stuff, changed ports to check if port is a problem.
Please Help
Does it show up in the BIOS? If so, try to clean install the graphics drivers.
Hello.
How did you accessed your device manager while the gpu is not giving any signal?
Is your display connected to the motherboard while the gpu is installed and it's giving a signal?
If yes check your bios and switch the preferred GPU to your external GPU not the integrated.
GoodLuck
