[SOLVED] My monitor turned off while I was using my PC and and now it won't turn on ?
Rashedul Islam Shawon
Commendable
Apr 27, 2022
16
Monitor model : Dell SE2219EX 21.5"
Problem : My monitor turned off while I was using my PC and the led indicator light started to blink continuously and now the monitor is not turning on. Sad part is it's not under warranty.
Please solve my problem. It's so urgent 😥
Have you read the Troubleshooting section of your monitors owners manual?
Blinking On/Off button light indicates that the monitor is in Standby Mode.
Your monitor features a Self-test mode that allows you to check if your monitor is functioning properly. Disconnect all video cables from the monitor and run the self-test feature.
Thanks for reply. Actually the self test mode was also not working. So, I took it in service center and they said some of main board parts have burned. So they replaced some parts and it's completely fine now.
Reactions: Phillip Corcoran
