[SOLVED] My motherboard won't turn on, is it dead?
MEETWIIT
Commendable
Mar 25, 2019
13
Hello there, so I switched the SATA cable from SATA2 to the SATA1 in my motherboard Gigabyte H110m-S2H, and when I tried to boot the pc again, my motherboard didn't want to turn on, I feel some electricity in the USB ports, but the fans, the CPU fans, the GPU, and everything doesn't turn on when I press the power button, I tried: powering up my computer and wait for a short beep, remove the RAM and the video card and power up the computer, resetting the RAM in other slots, trying another working RAM, checked if the motherboard speaker is properly attached to its designated slot, try the power supply in another motherboard and it worked very fine, removed the motherboard out from the case and place it on an insulated surface, resetting the CMOS, checking the capacitors and every way possible but nothing worked, I don't know the issue right now, I can't tell if its the PSU or the mobo or maybe the CPU, any fix?
my components are: i5 7400, h110m-s2h, 8GB ram and the PSU is Enigma SO-650 W and an Asus 1050 Ti.
Did you try to power it on using a screwdriver to short the PWR pins?
Just to make sure that your computer case's power button isn't faulty or the wiring is wrong.
