I have this problem for a while now and I still managed to turn my PC, somehow.
Im using my PC for about a 2 months now and these past few week my PC wont even start unless I unplug and plug my PSU cable then pressing the power button and repeat wishing my PC to start the next time I press the power button.
When my PC boots, I can use it normaly like nothing is wrong. But It changes when I shutdown my PC at night then I will have the same problem the next day. But I didn't mind it because I can still turn my PC on after a few tries of unplugging and plugging my PC, I can use it like normal when it turns on.
But now, It changed because my PC doesn't want to turn on anymore. There is power coming out of the USBs because of the idle lights on my mouse and keyboard. So I thought maybe PSU is the problem.
I have 3 PSU laying around here. 1 brand new for reserve, but non of the PSU managed to start my PC.
I have read that maybe its a sign of a dead or dying CMOS batter, so I swapped It as well, No luck.
I have tried reseating everything, CPU, RAM, CMOS. (I dont have GPU). I tried reseating cables as well but no luck.
I tried swapping power cables, nothing works.
Before this happens, I notice that my PC sometimes turns on by itself. I remember pressing the power button once but I got no signs of it turning on so grabbed my stuff downstairs to try and open it, But when I went back in my room, My PC has already booted up. I managed to use my PC the whole day no problem.
I tried:
-Replacing CMOS
-Reseating Everything
-Swap PSU
-Test Ram one by one
-Tried jump starting
I even tried removing the mobo on the chasy and jump it with just the CPU and PSU on board because apparently screws can prevent your PC from even starting because of shorting. It didn't even start.
Can it be a faulty mobo problem?
SPECS:
AsROCK A320m-HDV
Ryzen 3 2200g Vega 8
16GBs RAM 2x8 DDR4 2666 hz
RAKK RK400 ATX PSU
I tried:
-Replacing CMOS
-Swap PSU
SPECS:
AsROCK A320m-HDV
RAKK RK400 ATX PSU
