I have 16 GBs of DDR4 RAM, and when I play GTA V for example, I can see that my computer is only using about 3-3.5 gigs of RAM.
I think this is the reason that my fps is only 40 fps sometimes and that the map doesn't load fast enough. I have an i5-7500 and a GTX 1060 6 GB so it should easily run GTA on high settings 60+ fps, and it has been like that before this issue.I also checked the RAM usage with Resource Monitor, shows the same thing, and RAMMap. It is not beacuse of cached memory, the game doesn't use more even if there is about 8 gbs of free RAM. Also tried with Rainbow6, it does not use more than 3 either, but it runs fine.
Does anyone know this issue? Thanks for your help
