Hi,
I installed a new processor (5800x3D) on my motherboard (ASUS Prime B450M-K) then plugged the water cooler (Masterliquid ML360R RGB) on my CPU. I installed all the parts then started windows 11. It booted finely. I used CPU-Z for bench and stress test. Everything seems okay. When the processor works, pump is working. I hear the sound, fans star to turn faster, I feel the cold coming out from the radiator. Then I restarted computer. It boots again. I did the same tests without any issues. Then I removed the 3-pin cable I connected to 4-pin CPU Fan. Checked some others as well. Now my computer won't start. The screen remains in stand by mode, there's no power on keyboard & mouse either. Rams are working as well. Power is coming from PSU to motherboard, LEDs do appear to be working. Checked CPU cable goes to motherboard and PCI cable goes to GPU. They are correct. I started the system and booted windows but now something is not working. I also noticed that pump is also working when the PC starts. It doesn't make any sound. Is it the mobo, CPU or GPU? Any ideas?
