Build Advice Need a GPU and build that will match my games.
vertoxed
Commendable
May 16, 2023
21
(1920x1080 / 144hz) Will be mostly competitively playing games like Escape From Tarkov, Counter Strike, and Rainbow Six Siege while prioritizing fps, but will sometimes play AAA and would prefer medium to high settings and don't care much about ray tracing.
I would like to purchase one of the 4070's but im not sure which version. Or is that overkill for what games I'll be playing?
Here is a list someone put together for me:
https://pcpartpicker.com/list/JN7DMV
Reactions: Lucky_SLS
You can pick up pretty much any RTX4070 out there. What sort of a budget have you allocated for your GPU purchase? Are the three titles you're mentioned above the only games you'll be taxing he system with? I ray tracing isn't what you're looking for, you could look at AMD's alternative and perhaps something lower spec'd since two of the titles you've mentioned above are e-sports titles which means they don't need much oomph from the GPU to play.
That processor can take on any game or GPU so only your budget is a factor.
Reactions: vertoxed
Just a few minor changes to your build.
1. better quality ATX 3.0 psu.
2. board with better audio codec: Realtek 4080
3. faster RAM: DDR5 6000 CL30
4. better quality case.
5. pretty much the same gpu but for cheaper.
https://www.msi.com/Power-Supply/MAG-A850GL-PCIE5
https://www.msi.com/Motherboard/MAG-B650-TOMAHAWK-WIFI
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($389.00 @ Amazon)
CPU Cooler: Thermalright Phantom Spirit 66.17 CFM CPU Cooler ($37.90 @ Amazon)
Motherboard: *MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard ($185.99 @ Amazon)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($94.97 @ Amazon)
Storage: Crucial T500 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($149.93 @ Amazon)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card ($799.99 @ B&H)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case ($96.99 @ Adorama)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($94.99 @ Newegg)
Operating System: *Microsoft Windows 11 Home Retail - Download 64-bit ($123.94 @ Walmart)
Total: $1973.70
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2024-02-04 03:28 EST-0500
Max budget for gpu would be around 800 but I dont want to spend that much if I dont have to. The games that are listed are what I will be mostly playing, but might play games like Cyberpunk 2077 for example. I would like decent fps 100 on medium settings on the higher end games. I have realized AMD is better for more competitive games, but I would rather pay extra as im more familiar with Nvidia and use its software regularly.
Total: $1973.70
thanks for your help. For the case, i like the more sleek and boxy ones, for example: https://www.amazon.com/dp/B09VNZHL44?tag=pcpapi-20&linkCode=ogi&th=1&psc=1
Would it be possible to change the case to something like that? it doesn't have to be nzxt just something more boxy and sharp without the round corners.
the TT GF A3 850W is a good model. complies with ATX 3.0 spec and is a tier A model. I see no issues there.
For 1080p, the 4070ti is definitely overkill. The vanilla 4070 is all you need for 1080p 144hz.
If you dont care about ray tracing, and want a more budget option, the RX 6750 XT is also a good choice.
Personally I would do it similar to @Why_Me but with some different parts swapped around and with a 4070S instead. I do not believe any of those games you are playing really need all that GPU horsepower at 1080p, mind as well save 200 dollars. I play tarkov at 1440p and get 100+ fps every map with exception of streets where I get around 85-90 depending on where I am. I have a less powerful CPU with the 5800X3D and a 3080, which is about 10% slower than a 4070S. Here is how I would do it.
CPU Cooler: Thermalright Phantom Spirit EVO 69 CFM CPU Cooler ($42.99 @ Amazon)
Motherboard: *MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard ($205.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($106.99 @ Newegg)
Storage: Crucial T500 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($142.49 @ Best Buy)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 SUPER 12 GB Video Card ($599.99 @ Newegg)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($119.99 @ Amazon)
Total: $1828.37
Generated by PCPartPicker 2024-02-05 13:02 EST-0500
Reactions: Why_Me
Hi vertoxed -
Your question in the title - "Need a GPU and build that will match my games."
Have you checked systemrequirementslab.com ? For just about any game out there, this site will tell you the minimum and recommended specs. That will give you good confidence in the HW selections you make, as well as help you know in advance if you're overbuilding.
It's also a great way to answer "... what if I want to play X in the future? Will my current build handle it, or what will I need to upgrade at that time?
Hope this helps!
Forgot to put this in the post but i eventually plan to upgrade to a better monitor any way but thank you for the recommendation
Total: $1828.37
Thank you for the suggesting ill see which one i like better. My 1660 ti does NOT like streets lmao
Reactions: helper800
