[SOLVED] Need a short ITX Case to fit in shelf.
markc1999
Commendable
Nov 13, 2018
46
I need under 11" tall and maybe 9"ish wide. Length is less important.
I have an ASRock Z390 ITX mobo
RTX 2070 Super GPU
Seasonic FOCUS PX-750 power supply
Noctua NH-L12S CPU cooler
Any suggestions?
Ordered the case. I will see if my current PSU fits. If not I'll see about that one. Thank you for your help
The PSU will "fit", I've used the 110 before myself with a similar sized ATX PSU..... but it'll be tight with the cooler.
It might actually fit - found this image:
https://pcpartpicker.com/b/DFTCmG
Which looks like it'll leave the full clearance for an ATX PSU over-top.
Now whether or not it'll perform ideally.... is pretty obvious. But it looks like it should 'fit' at the very least.
So uhh. Yea, it fit. Seems to be fine.. however... WAAAAAAAAAAAAAAAAY too short to hold the GPU... Damn dude.
I just went ahead and left the shell off, and used a PCI-E extender or w/e they are called to basically just plunk the video card on top of the case (fans up)
It's working fine (I'm on it now)
