Need advice on cooling setup for Corsair Air 740
Jun 14, 2018
So I plan on building a desktop when the latest Nvidia GPU's hit the market soon and I feel confident with everything I've planned out except cooling.
The PC parts:
CPU AMD Ryzen 2700X
CPU Cooler Corsair H150i Pro
Motherboard Asus - ROG Crosshair VII Hero
GPU will be whatever AIO Watercooled GPU EVGA releases for the next Nvidia GPU's.
And the case of course will be the Corsair Air 740
So here's how I plan on setting it up
Front of the case is where I will put the 360MM AIO Radiator outtake (only spot in the case where I can put a 360MM radiator)
The back will be where the GPU AIO radiator will outtake
The bottom and top will have 2 140mm fans doing intake
So what I'm wondering is will this be the best cooling setup for my build?
I'm a little concerned because I hear having intake fans at the top is not the best idea, If I could put the 360mm radiator at the top I would, but the front is the only place
So what should I do?
Got an Air 240. Airfilter is in front. Blowing is back and up - got 2 Corsair pulling the air up. PSU compartment sucks through filter from right and blows out back. CPU Watercooler goes vertical behind intake. The intake filter make this a dustfree case and not much dust is getting blown out. Thats the optimum case and the way it is designed. It might be out for a while but is a superb design and really looks cool withs retro 70 Cray look.
