Need Advise FOr BEST Graphic Card for my PC
Aleisho360
Ok i need to upgrade my video graphic card as the one i have now is a no no for this new next gen games tech theyre pulling out, i have an XFX FORCE radeon HD 7000 series and i need to know whats THE best card i can get my hands on, that will be able to run battlefield 4, i want advise on whats the best i can get versus what i need, and which one would get the job done and not cost as much, my system specs are: a motherboard ASUSTeK Computer INC. P8Z68-V LX (LGA1155), GPU:AMD Radeon HD 7700 Series RAM: 8.00 GB Dual-Channel DDR3 @ 668MHz (9-9-9-24) and CPU: Intel Core i7 2600K quadcore. please help me i kinda get desperate when i see my computer getting obselete, o my Powersupply is 600watts its an XFORCE i believe
M0kujin
202
you only need to change your graphics card your system is all good to go no need to change anything even the PSU.
R9 280x and R9 290x is the best cards for BF4, because both cards will have a mantle support and BF4 is one of the games who will benefit from mantle. they can also max every game you throw at it on 1080p.
Aleisho360
Really? shouldnt i change anything else? also ive seen that the R9 280x and all alike graphic cards are 3.0 pci Gen and my MOBO is 2.0 will that affect me at all? also the connector to my powersupply i only have a 1x6pins and most of these need like 2x6pins and other weird connections. can i just but adaptors for the power cords or sumthing like that? what are my other options?
M0kujin
202
Yes PC 3.0 graphic Cards will work on PCI 2.0, you don't have to change your mobo.
but the problem is ur PSU, not sure if it will work or you can use adaptor, better change that too, you need 1x6 and 1x8 pin connector to work. maybe its time to change that too :)
Aleisho360
I believe its CX ATX 600watt PSU its from buyxg.com
M0kujin
202
If you got that, you all good. Buy 280x
If you want the 'best' it's probably this card http://www.newegg.com/Product/Product.aspx?Item=N82E16814487003
If you want one based on needs, it depends at what resolution you are playing your games. Also do you do video recording, streaming, editing, encoding, 3D gaming, or any kind of specialized work on the PC?
Also you might want to consider getting faster ram. 668Mhz is really slow and according to the latency it should be running faster. You sure it's not 1333 or 1600Mhz?
Your processor is fine. PSU is sufficient for a new graphics card.
Maybe also tell us your budget (in your local currency) as well as the website of the store you gona buy from.
Blaise170
Dual channel 668 which translates to 668*2=1333
Aleisho360
lets say i dont want to spend more than around 550$ MAX, no i dont do any streaming or recording sof the sorts i just want to be able to stay better than this new next gen consoles, and run new gams and those to come at ultra settings and still be at 60 FPS or atleast high, never thought about 3d gaming might be an option, my screen is just 1920x1080p max res which is what i play, and i have NO IDEA what to buy and where should i buy it i am REALLY considering an R9 280x BUT i dont know from which sotr online can i find it or which prodcution line has the best if xfx or sappire gigagyte, etc, thats why im here to get the best feedback recomendations and make a decition based on that, thanks for ur feedback :)
