Question Need help 660 Ti Graphics card - i5 2500k installation
Mar 26, 2020
Hey guys,
Just bought a used it i5- 2500k
12gb ddr3 ram
450 W supply
Motherboard - P8H67-M- Pro - Asus Global ( I guess it's called)
And I just bought a 660 ti graphics card to put in here.. I didnt really know what I was doing and figured it would be simpler than it is.
Running into the issue "shut down and connect the Pcie for this graphics card.
I have a 6 pin connected into the graphics card. There is also an 8 pin connected in the corner of the motherboard, when I unattached that the computer wouldn't turn on .. please help!
King_V
Does the card only require a single 6-pin, or does it have another plug on it? Is it fully seated?
