Need help about Geforce GT 420
sealtanya
7
I'm going to buy a PC which include GeForce GT420, I wonder if this card can play every game smoothly like Crysis 2 and battlefield 3,which is coming this year.I like those action shooting games but I don't need extreme settings, high or very high is enough for me. This is its specs:
2nd Generation Intel® Core™ i7-2600 processor 3.4GHz
with Turbo Boost Technology up to 3.8GHz
Windows® 7 Home Premium 64-bit 2
Intel® H67 Express Chipset
8192MB DDR3 Dual-Channel Memory Packaging and Documentation
1.5TB SATA Hard Drive (Green Product - variable RPM)
NVIDIA® GeForce® GT420 Graphics
with 1GB of Discrete Video Memory
16X DVD±R/RW SuperMulti Drive
Multi-in-One Digital Media Card Reader
10/100/1000 Gigabit Ethernet LAN (RJ-45 port)
802.11b/g/n WiFi CERTIFIED™
High-Definition Audio, 5.1-channel Surround Sound Support
P/S: Thanks for advance. :d
Maybe i'm playing it in 1024x768, if that's not enough, can u suggest me some that help improving the performance.Because it is sold in package so I'm not sure that I can change the GPU. I searched them on FRys.It costs $900. :??:
You would be better off building your own computer and putting it together for that price. I just build my aunt a much better computer for less than that. Even if you are playing at 1024x768 I would recommend a better card than that.. thats a really low end card.
oh, i see. But I'm not good at building computer. Do you know where can I choose the hardware and have them builded for me? Can you suggest me another specs and how much do they cost in total?
Building computers is as easy as building Lego sets or Ikea furniture. If you want the best bang for your buck, build an i3 Sandy system and pair that with an AMD (5/6)770. That should more than cover your resolution.
Yup, just gotta know which end is up. Should take you no more than 30 minutes for assembly and making sure that everything powers on plus an hour or two to let Win7 install + download drivers. If you have an old, broken PC you can use, try taking that apart first. Might give you an idea on how it works.
Can u look at this, is this one better?
Intel core i5 2500K 3.30 GHz ( unlocked CPU for extreme overclocking) ( quad core)
Asus P8P67( Intel P67 Chipset)(New B3 revision) (Does not support SLI)
8Gb DDR3 1600MHz Digital Storm Certified Performance series
HDD 1TB Hitachi/Seagate (7200 RPM) (32Mb cache)
Nvidia Geforce GTX 560 Ti 1GB (include PhysX Technology)
High Performance cooler
Microsoft Window 7 Home Premium ( 64 bit edition)
Overclock the processor bettween 3.3GHz to 3.9GHz
if your not quite sure on how to build a pc, you certainly should NOT look into overclocking. It is for advanced PC builders only. With the setup your looking at you should not need to overclock anything anyway. When the pc starts to feel slow in a few years you can look into overclocking and do lots of research first.
This is more than enough for those games. It should run smooth on medium in both games. I would reccomend upgrading to a GT 740 if you can, though.
