Question Need help choosing cooling pad
May 3, 2024
Hey I'm looking to buy a cooling pad for my Asus Tuf F15 2023 edition(i7 12 gen, 4060 8 GB) I'm considering buying the cosmic byte cyclone or Archer Tech Squall 300, but I'm confused between the two, I would appreciate it if anyone could help me out. Thanks
Either will work, though where are you located and have you tried undervolting your processor and GPU to lower your temps? You can even use higher quality thermal paste and thermal pads to help tame the temps in your laptop.
