[SOLVED] Need help deciding amongst 4 prebuilds
kristian20
34
9
4,535
Hey!
I have a few prebuilds in mind, but im not quite sure what would be better for me. I want it to be able to run my 3 monitors, play games at 144 hz over 100 fps and in the future VR games.
My current pc acts out when i use all 3 screens the ram and cpu shoots up and youtube just freezes.
Below are the setups Im considering, some are luquid cooled and say they need no maintenance not sure if thats true or not. Also wont be using wifi.
1: Komplett Premium a145 Gaming Dator - I don't know enough about ryzen in general.
graphics card: ASUS Radeon RX 5700 DUAL EVO OC
CPU: AMD Ryzen 7 3800X
Cooling: CM Masterliquid ML120L ARGB Komplett Edition
DDR4 memory HyperX Fury RGB DDR4 2666MHz 16GB,
SSD: Samsung PM991 512GB M.2 SSD,
Motherboard: ASUS ROG Strix B450-F GAMING, Socket-AM4
PSU: Corsair TX550M, 550W PSU
2: Komplett Gamer - Crazy Core i9 Edition - Actually considering this build, could upgrde the graphics card to ASUS Radeon RX 5700 DUAL EVO OC for about 200 USD more.
graphics card: ASUS GeForce GTX1660 DUAL EVO
CPU: Intel Core i9-9900 Processor
Cooling: CM Hyper H411R RGB Black Edition
DDR4 memory: HyperX Fury DDR4 2666MHz 8GB
SSD: Kingston A2000 250GB NVMe M.2 SSD
Motherboard: ASUS TUF B360M-Plus Gaming, S-1151
PSU: Cooler Master B500 V2 KOMPLETT Edition
Network card: Svive Gaming Virga
3: Sharkgaming espot edition - considering this one as well might upgrade the ram to: Corsair Vengeance RGB PRO 2x8GB 2666MHz RAM
CPU: INTEL CORE I7-9700F
Graphics card: ASUS DUAL RTX 2070 SUPER 8G EVO
Motherboard: ASUS TUF B360-PLUS GAMING BUNDKORT
Liquid cooling: COOLER MASTER ML120L RGB
Ram: KINGSTON HYPERX FURY 2X8GB 2666MHZ
PSU: FSP HYDRO 700W 80 PLUS BRONZE STRÖMFÖRSÖRJNING
SSD: INTEL 660P 512GB NVME SSD
Soundcard: REALTEK® ALC887-VD2, 8-CHANNEL HD AUDIO CODEC
Network card: REALTEK® RTL8111H, TUF LANGUARD
4: Mighty shark deep blue
CPU - INTEL CORE I7-9700KF PROCESSOR
Cooling: SHARK GAMING BLOODFREEZER 360 RGB WATERCOOLING
Motherboard: MSI MPG Z390 GAMING PLUS BUNDKORT
Graphics card - ASUS ROG STRIX GTX1660 SUPER O6G GAMING
RAM - KINGSTON HYPERX FURY RGB 2X8GB 2666MHZ
PSU - FSP HYDRO 700W 80 PLUS BRONZE STRÖMFÖRSÖRJNING
Soundcard: REALTEK® ALC S1200A
Network card: REALTEK® L8200A GIGABIT ETHERNET, FEATURING TURBO LAN
Thanks in advance!
9900K isn't worth it imho for price to performance, plus your missing the GPU.
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor (kr3490.00 @ CDON SE)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard (kr1548.10 @ Newegg Sweden)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory (kr1168.00 @ Dustin Home)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive (kr1673.00 @ Dustin Home)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive (kr749.00 @ CDON SE)
Video Card: Asus GeForce RTX 2070 SUPER 8 GB DUAL EVO OC Video Card (kr5999.00 @ CDON SE)
Case:...
For running "3 monitors at 144hz at 100fp in VR" you really should go with a build where you pick your parts and really need a top of the line video card unless you are only going to be using one screen for gaming. High resolution + high FPS + high frame rates you need a high end video card that can run 4k games at high fps. I don't think any card past the top tier ones can do that yet.
Three 1080 monitors (assuming that is what you have) are maybe 20% less resolution than a 4k screen, so your goal should be to find a video card and CPU than can handle 4k gaming at the FPS you want.
