[SOLVED] Need help deciding between 2 laptops
If you put them side by side you will see cosmetic differences but the performance is basically the same.
i5-9300h vs i5- 8300h... like 2% different
1050 3gb vs 1050 2gb...like 1% faster when more VRAM is needed.
SSD are the same
RAM is the same
Screens.. Asus is a little better
Speakers- Asus is a little better
Chassis- Asus is a little cleaner and pleasing to look at.
Overall the same but still the IDEAPAD is just slightly faster.
IDEAPAD GAMING L340
The ASUS has a slightly better screen quality and the speakers are a little louder. The Ideapad is just a little faster but not by much...... 2% at best.
OK so what you're saying is they're pretty much the same? I thought the Asus would be better built and more resistant or smth, given the difference of price from the Lenovo, and having lower specs
SSD are the same
RAM is the same
Reactions: Crowie
SSD are the same
RAM is the same
Okay, thank you for the fast reply!
