[SOLVED] Need help fixing my keyboard
Dec 2, 2020
4
Hey, my keyboard just recently started going berserk, like, w activates caps lock, o activates f7, etc. Anyone know how to fix it, it was working perfectly till today.
You could try reinstalling the Keyboard Driver.
If you open up Device Manager, Look for keyboard and you should see something like this:
Try Uninstalling the HID Keyboard Devices only.
If its a mechanical keyboard i.e. with a cable etc then it should automatically reinstall the drivers after you take it out and put it back in. Otherwise Restart your PC/Laptop.
