• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Need Help for Graphic Card Selection
ckfchong
8
Dear all,
I need help for the graphic card selection.
I have Intel Core2 Duo 2.8GHz, 4GB DDR2 RAM, Power 550W ATX PSU, motherboard Gigabyte GA-EP43-UD3L. Previously I am using graphic card NVidia XFX GeForce 9800 GT, but it seems like spoilt recently.
Now looking for alternative graphic card. My PC is used for the gaming.
Thanks.
ckfchong
8
Monitor 22 inch Widescreen LCD 1920x1080 ; not so sure about power supply model, it is 550W ATX PSU ; budget less than USD150.
Thanks
jjb8675309
Splendid
yeah, but your psu seems suspect you should look into that, open the case, read the specs, and even at that it may not provide the specs it says if it is a no name psu, not a smart idea to run a *** psu, just saying.... for 1080p I would go no lower than a gtx 560ti/ HD6950, you will also need to oc your cpu a bit.
If all you can afford is 150 then get a 6850
I agree with you need to check the CPU but you don't need a 560Ti or a 6950 as a minimum for 1080 more like maximum before its overkill. I have 2 4870s in crossfire which gives performance somewhere between a 6850 and a 6870 (no direct X 11 though) and I can play all the games I have on Ultra settings with no lag.
ckfchong
8
my power supply is 550 with Cooler Master.
With my current spec, previously I get GeForce 9800GT, shall I get back the same or my spec can support higher end graphic card?
jjb8675309
Splendid
yeah I'd say a 6850 is a good choice given your 150 dollar budget you can't go much higher, I think the 6850 will suit you well
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908&cm_re=6850-_-14-102-908-_-Product
if that is too much for you then I would go for a 5770, it will be more powerful than your 9800gt but its no 6850:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121363&cm_re=5770-_-14-121-363-_-Product
really for under 150 you really cant get the 6850 so maybe the 5770 is your best choice.
jjb8675309
Splendid
I would also recommend trying to OC your CPU to around 3.4 ghz if possible bc any graphics card that you buy will be a bit held back with your dual core clocked at 2.8ghz, so to obtain optimal performance given your hardware, OC your cpu a bit if you can, that is the only other thing I would recommend to someone in your situation
Mrsh4dy
105
4
If you know the exact power supply model we can be of further use to you.
We need too know the amps on the 12volt rail of your psu, not enough amps and you'll underpower your graphics card.
What I have found indicates that you need about 12-15amps on the 12 volt rail to run a 6850 too be on the safe side lets say the 6870 requires 20amps. If your psu matches that you should be good to upgrade to either of those cards.
A quick search said the 9800GT needs 22amps, by that knowledge we can assume your psu has atleast 22amps which should make it able to run a 6850/70 which are the cards most would recommend.
jjb8675309
Splendid
no the 6790 is a trash/fodder card, bad power consumption/performance, and bad price/performance, Do not get a 6790, get either a 5770 or 6850 they both respectively offer lower power consumption and better price/performance
ckfchong
8
Dear all,
I still have 1 more query.
Does my motherboard GIgabyte with Intel P43 express chipset (Socket775/PCI-E2.0x16/PCI-Ex1/ATX/ 4 DDR2 Dual-CH) support the ATI HD5770?
Thanks
Similar threads
