[SOLVED] Need help for selecting components.
Icebreaker8236
6
Hello everyone! I am planning to put together a computer which I'll be using for software development and gaming.
In gaming, I mostly play sim-racing titles and I am planning to upgrade my display to a 4K display in the future.
In sim-racing I play iRacing, Assetto Corsa Competizione, Assetto Corsa, F1 2020.
I need some help in finalizing all the components. The components that I have shortlisted are as follows,
CPU: Intel Core i9-11900K
Motherboard: GIGABYTE Z590 AORUS ELITE
RAM: CORSAIR Vengeance RGB Pro 32GB
GPU: MSI GeForce RTX 3070 Gaming X Trio
M.2: SAMSUNG 980 PRO M.2
SSD: WD Blue 3D NAND 2TB
PSU: CORSAIR HX Series HX850
CPU Cooler: NZXT Kraken Z63 280mm
Case: NZXT H510i
Any suggestions are welcome!
Thanks!
Reactions: Why_Me
Case...
Everything is good except the case.
A close front panel with only 1 rear and 1 top exhaust fan isnt something i would put in a 11900K/3070 in.
Also 11900K, for gaming only??
And at 4K?
At 4K, there would be little difference between a 3300X and a 11900K, since that is all on GPU.
That is way overboard.
But with the given "budget", something like this would make way more sense imo:
PCPartPicker Part List
CPU: Intel Core i7-10700K 3.8 GHz 8-Core Processor ($325.64 @ Amazon)
CPU Cooler: Corsair H100i RGB PLATINUM SE 63 CFM Liquid CPU Cooler ($159.99 @ Newegg)
Motherboard: ASRock Z590 Extreme WiFi 6E ATX LGA1200 Motherboard ($214.99 @ Newegg)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($174.99 @ Best Buy)
Storage: Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive ($319.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 3070 8 GB GAMING OC Video Card ($1399.99 @ Monoprice)
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case ($162.56 @ Amazon)
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($144.99 @ Best Buy)
Total: $2903.14
Generated by PCPartPicker 2021-03-16 15:53 EDT-0400
Probably overkill on the drive. 980 Pro is very good, but do you have storage needs like that? I suggest going down to the 970 Evo if you don't plan on massive data transfers constantly.
Additional SSD is okay, though best to start off small. Or go for a 2TB M.2 SSD to start.
Intel, not a good choice. Rival Ryzen 5800X wipes the floor with it in all but a few tasks. Cheaper motherboards too.
3600Mhz memory would be more in keeping with Ryzen or an overclockable Intel.
HX850 is a little large for the build. A good 650W should do. Though with prices as they are, if it is $180 for 650, why not 850 for $200.
And of course, good luck with getting an RTX 3070.
And at 4K?
Total: $2903.14
I thought of 11900K because I am going to use the system for software development as well, and planning to use this computer for a while.
Noted. I was a little skeptical about Ryzen and AMD because of bad experiences in the past, but after taking a look at it, it seems like a viable option.
PS: Hope I can get one RTX 3070 at a decent price this year 😛
Yes, B550 as well. I do recall some rumors that it affected B450 with Ryzen 5000 CPUs, but I never saw anything on X470 etc. But if the fix solves a fundamental problem, all the better. PCIe 4.0 and USB conflict or something.
Just odd that it seemed to pop up all of a sudden, when people have had these boards for a good while. Maybe paired with a Windows update, or one of the previous AGESA releases.
Don't own one, so going by second hand knowledge only on this.
Reactions: Dj0gany
So, I've been digging around some configurations and came up with this.
Apparently, the motherboard listed here has a USB Flashback capability so I'll be able to flash the BIOS without an older CPU in it.
Let me know what you think about this build.
Case: NZXT H510i
Thanks!
You might want to have a look at the i7 11700K ... same amount of cores for cheaper.
https://www.newegg.com/intel-core-i7-11700k-core-i7-11th-gen/p/N82E16819118233
Intel Core i7-11700K Rocket Lake 8-Core $418.99
And something like this Seasonic psu to save a few more dollars.
https://www.newegg.com/seasonic-focus-gm-series-focus-gm-850-750w/p/N82E16817151231
Seasonic FOCUS GM-850, 850W 80+ Gold, Semi-Modular $126.99
https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232885
G.SKILL Aegis 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) CL16 Intel XMP 2.0 $159.99
And with the money saved look into an RTX 3080 if you plan on gaming at 4K.
Thanks! Also, if overclocking is not a priority and if I decide to go for a non K CPU, how much of a performance difference does that make?
Slim to none although if you feel you need the extra 6 - 8 FPS you can always unlock the block multiplier (turbo boost) .. just make sure you have a decent cpu cooler just like you'd need for an unlocked cpu.
Asrock gave theirs a name (base frequency boost).
https://www.tomshardware.com/news/intel-comet-lake-overclocking-asrock-base-frequency-boost
View: https://www.youtube.com/watch?v=S13Pdar7WKE
