[SOLVED] Need help formatting undetected ssd.
Dec 22, 2019
8
my pc refuses to boot up when my ssd that has the os in it connected. i bought a usb to sata cable and plugged it to my laptop and it wont show up 🙁
my ssd is ADATA SU760.
Whenever i plug in a fresh usb windows it lets me install it but it wont detect the SSD. Does That role out that the motherboard being the issue?
It's unlikely to be a motherboard problem, much more likely it's a defective SSD since it won't even work when connected externally to another PC (your laptop).
What cable are you using?
I have been using the two cables that plug in to the pc. My pc will not get past the splash screen and after a few minutes it would go to bios and if I disconnected the ssd and turned on the pc, it immediately goes to bios. I couldn’t format it using a usb with a fresh windows and my laptop will not recognize it when i connected it via adapter.
Looks like your SSD may be defective:
