My laptop has freezed only shows automatic repair then blank so i took out harddrive then it shows menu but without it i can not do anything cause all files are stored into it any help pls !!!
Hello joejohannesdavince8, install the HDD again and download Seatools for DOS. You may also try the drive on another computer and see if you get the same problem. Best of luck.
