Hi all,
Hoping someone can walk me through if this is a GPU issue or a PSU issue.
I bought this computer new back in 2012, the rig has held up well until just recently the GPU, an AMD Radeon HD 7950, appears to have died. I got a purple screen, rebooted, then a brown screen and since then nothing. I put the card in another machine, no output, so I figure it is dead. It had a good life.
After poking around, I found that a good update should be a Radeon RX560 (Due to budget) However when I put it in my rig, there is no screen, it doesn't even detect it. Fans spin, everything else seems to be ok.
I put it in another rig, booted up with no issues. So I'm wondering if my PSU is starting to go and does not have the output? I'm at my wits end with this and do not have the capital right now to buy a new rig (It's on the wishlist though)
The only card I have been able to get to work is a Radeon HD 7700, runs straight off the MOBO, no extra power required. There is not an onboard GPU for this system, it runs solely on the hardware you install, so some of thee suggestions already made around the forum are not possible.
Help please!
Current specs:
Hewlett-Packard h9-1170t 715
Power supply 600W
Board: PEGATRON CORPORATION 2ACE 1.08
UEFI: AMI 7.15 09/17/2012
3.20 gigahertz Intel Core i7-3930K
16322 Megabytes Usable Installed Memory
Windows 10 Home (x64) Version 1909 (build 18363.752)
Radeon Software version 20.1.3
Help please!
Current specs:
Power supply 600W
