G
Guest
Guest
I have a old Micron 90 mhz Pentium and trying to hook up an Acer CD Writer. There are 2 hard drives in the machine, 2GB and 840 MB. I gave the machine out to a tech to hookup the CD Writer and in place of the existing CD Rom.
When I got the machine back, it fails to recognize the CD Writer, only the two hard drives. The 2 hard drives are on one cable and the CD Writer on another cable. I try numerous scenarios but cannot get the CD Writer to work with second cable. Seems to be some form of interrupt conflict and one of the controller card does not install. I try manually changing the interrupt from 14 to another value but system would not accept it. This is funny as the motherboard shows the interrupts to be 14 and 15 for the IDE controllers.
I decided to give up one of the hard drive and just hookup the CD Writer with the 2 GB drive.
Question #1 - on the disk drive cable, does it matter if I plug in the first cable socket to the hard drive or the CD Writer? Currently, cable comes from the mother board to the hard drive and than to the CD Writer - which is configure as a slave.
Question #2 - The Acer manual recommends that the CD Writer be on its own controller and recommend the use of the second IDE. What I am losing by hooking up the CD Writer to the primary cable as a slave to the hard drive?
Thanks in advance for all help.
