Hi everybody,
I purchased an old Samsung TV (UN19F4000) with the intention to install a hardrive inside of it. The TV has a USB slot, and the plan is to wire a storage device inside the back panel and seal it up, bypassing the external USB port.
However, I cant tell which wire is which as the TV will not fully open up.
So, I was hoping somebody could identify the two cable types in this photo, and tell me which one is likely the data transfer cable leading to the USB port.
Thanks!!
Thanks!!
