need help in gaming pc
swarnava dey
316
Hello friends I am from India . I want to build a gaming pc. I want to whether my configuration is good or not
Processor - i5-4690k motherboard - asrock fatal1ty z87 killer. ram - corsair vegenance 4gb. graphics card - gtx 970 (Asus). case - cm storm enforcer ( power supply included in it). hard disk - wd cavier 1tb Display - 32inch full hd led tv . regarding display I want some help from you guys. I want to use a led tv for gaming since I don't want to buy separate monitor. So shall I buy Sony bravia 32inch or 28inch . Is full hd display very much important for gaming.please help me.....
this is personally the rig I'd run.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($214.89 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($106.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($69.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($118.98 @ OutletPC)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($87.99 @ NCIX US)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card ($328.99 @ Directron)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($99.99 @ Amazon)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($66.98 @ Newegg)
Total: $1124.67
Generated by PCPartPicker 2015-02-25 05:01 EST-0500
ah hes in india. Neglected to see that though I had large suspicion.
Here's my indian gaming build!
I think all of these are available in india, please check however!
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($62.99 @ Newegg)
Case: Corsair Air 540 ATX Mid Tower Case ($125.09 @ Amazon)
Power Supply: SeaSonic 620W 80+ Bronze Certified Fully-Modular ATX Power Supply ($80.99 @ SuperBiiz)
Total: $1156.88
Generated by PCPartPicker 2015-02-25 05:18 EST-0500
Dear friends I had only abudget of rs 75000 and not more than that. Please remove components like ssd and liquid cooler. Except display ; keyboard and mouse; and ups . Tell me other components ..and another thing I am going to get all the components from mdcomputers.in .
that didn't make too much sense to me.
I added an SSD to add a faster boot and stuff as such, I'm running an SSD and I've never seen anything like it, honestly they're a must have!
I haven't put in a liquid cooler only an air cooler.
Keyboard mouse and monitor, do you want me to add these within the budget?
Asus GTX 970 28,350
i5-4670k 16,075
ASrock z87 killer 12,700
8gb ram 5000
Antec neo eco power supply 520w 7,500
1tb hard drive 4700
Coolermaster 311 cabinet 2500
Total 77,000 or so
I would rather drop to a non overclocking CPU and H97 board to get an SSD in for the price. You could also get a cheaper PSU as well if you aren't overlcocking
Do you already own an SSD? And when you say UPS do you mean PSU? In the UK, UPS means one of these:
http://www.ebuyer.com/238120-apc-power-saving-back-ups-pro-900-230v-br900gi?utm_source=google&utm_medium=products&gclid=CIuz5oCS_8MCFRHKtAodhSgAaw
and PSU means one of these:
http://www.ebuyer.com/484277-xfx-xxx-850w-semi-modular-80-bronze-power-supply-p1-850x-xxb9
I am having problem regarding motherboard. I have some options Asus sabertooth mark2 ; Asus Maximus vii ranger ; Asus z97-a ; and Msi z97 gaming 5 or 7 . and regarding overclocking I dont know how to do that but I will learn that later that is not very much important to me. Just help me in selecting he motherboard and please refer the site Mdcomputers.in I am buying everything from there only.about ssdi will try to get that later on and also the extra 4gb ram.
If you're not overclocking I wouldn't suggest a board as advanced of any above I also wouldnt suggest a K series cpu. This means a 4460/S would be more applicable so we can edge a little more on the GPU.
This also means I'd suggest a H97 Pro gamer board.
Would you like a recalculated build?
Asus Motherboard consider as one of the best and reliable. You have to add 8gb ddr3 RAM, 1TB of HDD and also need an extra 120GB or More SSD for hardcore gamine. i5, i7 is best option. for graphics card I would suggest you to use nVidia Geforce or GTX with dual GPU. For monitor you can go with AOC, or BenQ.
As guys have said if it is not necessary to overclock then I would go for a non overclocking gaming pc . Please suggest best components From MDcomputers.in . Now my buil
Processor - i5-4690
Motherboard - Asus h97 pro gamer ( if there is a better mobo than please suggest me)
Graphics card - gtx 970
Ssd -suggest a cheap good one.
Hard disk - wdd cavier 1tb
Drive- Samsung optical drive
Ram - corsair 8 gb
Please and say the among from MDCOMPUTERS. Thank you for helping me.
