Hey!
My computer has been running on a single SSD and everything is installed on it, but now that I bought an NVMe M.2 drive to expand the storage I want to install it the right way, so I have a couple of questions regarding the correct process. I'll be using my computer for primarily for gaming.
System Specs:
![Smile :) :)](/data/assets/smilies/smile.gif)
Thanks!
System Specs:
- OS: Windows 10
- Motherboard: MSI B450 Gaming Pro Carbon AC
- Current Storage: Samsung 860 Evo SSD (250GB)
- New Storage: Samsung 970 EVO Plus M.2 (500GB)
- Should I install the M.2 drive into the computer and run it normally, just like plugging a usb drive?
- Should I install the M.2 drive into the computer, format the entire system and only then use it normally?
- Should I install the M.2 drive into the computer and run some specific operations for it to be installed properly?
Thanks!
