PC Parts: https://pcpartpicker.com/list/Wb7Yp2
Hey!
This is my very first 'own' build, basically all done by myself and after a bad experience years ago I never did anything on my hardware again until now. I hope I found the right sub-forum for this entry as well.
Please don't kill me or go for the 'read the manual', I did, watched videos and I am still scared <Mod Edit>.
Could someone do me a favor and tell me if they see a mistake with the cables I connected?
Mainboard:
View: https://i.imgur.com/kIx6HQL.png
A) Top left, CPU1 and CPU2, used the 8pins only, connecting them with P8/P4 below the PCIE1 slot. I didn't payed attention in which order the CPU 4pins were plugged into the top one as they were two seperated endings.
B) Top right, connected my Kraken's 3pin pump controller with the cpu_fan header. I've read I can do that or plug it into the AIO pump one near C, NZXT manual is saying either works, Motherboard says AIO, Internet says also both work (?).
C) The ATX cable is going straight into the PSU into the big MB slot and the smaller 8pin MB slot (unsure however
D) USB 3 connecting the front USB slots with my MB
E) Connected the rear fan with cha_fan1
F) A lot of small ones according to the MB manual, top left PLED+, beside that PLED -, then Power SW, below that the reset one.
G) cha_fan2, connected with the Corsair fan hub on the back, which has 2 splitters for front and side fans in slot 1 and 6 (cables were too short, an issue?)
H) The USB connection for the Kraken
I) Audio cable from the case
The additional USB from the case can't be connected with this MB (unfortunately, probably need an adapter?)
AIO:
Example Image
View: https://i.imgur.com/EC7Gjkj.png
- Connected the small fan cable with cpu_fan header Mainboard B)
- Connected the USB with Mainboard H)
- The 3 fans go right into the screen, so nothing done there (?)
- The RGB thing just hangs on the back of the case without a connection, like the one with '?'
- Connected with a PSU SATA cable that also connects with the the fan hub
Can cables just hanging around in the back of the case be an issue? Like I've had it in my older PCs, in this one, but never knew why that wouldn't be an issue. (see the AIO image reference '?')
The cables of the Z73 display are touching the RAM - issue? There's no space otherwise unfortunately.
GPU:
Example Image
View: https://i.imgur.com/xzhr1rI.png
Do I need to plug them into an order or anything?
PSU:
Example Image
View: https://i.imgur.com/7kJNQ73.png
A) & B) The GPU is connected with 3 8pins to the PSU, VGA1, VGA1, VGA2 (no specific order? I somehow killed a GPU years ago so that's the reason I am scared regarding current prices etc). VGA1 are both in PCIE1, VGA2 in PCIE2
C) & D) MB again with the big and smaller MB power connections
E) is connected with the Mainboard via a cable that has a CPU1/CPU2 label (see above, Mainboard A)
F) SATA cable that has several opportunities to plug things into and I have no clue how many things it can power. Currently has the AIO on it and the Fan hub, it's plugged into the bottom DRIVER one.
Fans:
Actual image
View: https://i.imgur.com/oI7puCP.jpg
View: https://i.imgur.com/G7g48ad.jpg
Fans of front, rear, and NZXT - does that configuration make sense?
Beyond thankful for everyone that could have a look and let me know if this works and I can set it up as my work would really need the additional power.
Thanks everyone!
Hey!
Mainboard:
AIO:
Example Image
GPU:
Example Image
PSU:
Example Image
Fans:
Actual image
Thanks everyone!
