Need help is this build is compatible
chobitshid
20
Intel i3 3220
Asrock H61M-DGS
SAPPHIRE HD 7770 VAPOR-X EDITION OC 1GB GDDR5
Corsair Vengeance 4 (4x1) 1600 CL9
Corsair VS450 450W 80% Efficiency
Western Digital Blue 500GB
Antec 100 Mid tower Case
Please Help me
they're compatible though you may need to ask the retailer/seller if that H61 board is loaded with the latest BIOS or at least version P1.30. while most times the answer is yes, people can get careless, so better safe than sorry.
http://www.asrock.com/mb/overview.asp?cat=CPU&Model=H61M-DGS
or if that's too much hassle for you, there's getting a B75 motherboard for more ease and guaranteed compatibility sans BIOS update.
