need help overclocking for first time builder
Butters5000
172
hello, was wondering if asus 5 way optimization is the way to go for a new builder and new overclocker or if i should do it manually? any help would be great.
i have used asus 5 way, and got it to 4.3ghz and 1.345 max volt, i tried it before setting it to 4.3 and got it to 4.7ghz and about under 1.4volts, think it was around 1.6v but wanted to be in the safe zone so moved it down a bit.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($227.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.88 @ OutletPC)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard ($150.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($74.89 @ OutletPC)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive ($62.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($45.71 @ OutletPC)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($69.00 @ B&H)
Video Card: Sapphire Radeon R7 370 2GB Dual-X Video Card
Case: Inwin 503 BLACK ATX Mid Tower Case ($65.98 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($58.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($84.88 @ OutletPC)
Total: $866.30
Generated by PCPartPicker 2016-09-28 02:51 EDT-0400
Hi,
Your voltages are pretty high, i am running i7 2600k @4.2Ghz with 1.150V , while my brother runs his i5 4690k @4.7Ghz with 1.275v.
You just simply do the overclock manually.
Go to BIOS, and under the Tab-Tweak, go to CPU Ratio, set it manually/sync all cores and set it to 40, while the BCLK is at 100 (40x100=4000Mhz or 4.0Ghz), set the voltage to auto.
Go into desktop and try the overclock with prime 95, real temp, and CPUZ to see the temperatures and voltages used (observe the voltage used during full stres).
After the stress test, you will have a broad picture where your overclock stands in therms of temperature and voltage.
Mind you, there is also the ''silicon lottery'' in question, some CPU's can reach 5.0Ghz , while some...
don't know what is wrong now, i reset it back to default and seems to be working better. but temps are getting a little high, almost back to the 80c, could the thermal paste be bad, it's like grey and blackish.
thinking i need to add another fan, because one is exhaust fan and the front one is where hard drives are, and the case while it looks good, the fact that the fans are behind a panel with like an inch and a half opening to suck air in, it's probably better to test another fan to see if it helps, before raging on it.
i just overclocked to 4.2ghz and set the volts to 1.232, then ran aida64 for 30minutes and the max temp they got to was 65c, is that good and do you think i could move it to 4.3ghz and still be stable? 4.4 would be max i want to go, but if not atleast 4.3 would be good
Glad you got it working and stable!
If your system is unstable at all, I would just drop it down to 4.3 -as you the 100Mhz you are losing is not going to effect you by much at all (outside benchmarks)
Happy overclockin'!
