I currently own an MSI z68 GD-65 mobo, with an i5 2500k cpu. I recently installed a fresh copy of windows 7 ultimate and updated all drivers including bios to the latest available. I had my pc overclocked before this at 4.4 (dont remember the voltage), but now I have it at 4.2 because I have the voltage setting in bios at 1.37 for a stable clock which I feel is very high.
My current setup
CPU core voltage = 1.37
vdroop = 75%
4.2ghz
Internal PLL overvoltage = enabled
EIST = disabled
Enhanced turbo = disabled
OC Genie button operation = enabled
DRAM frequency = auto
Memory fast boot = enabled
spread spectrum = disabled
system agent voltage (SA) = auto
Limit CPUID maximum = disabled
execute disable bit = enabled
intel virtualization tech = enabled
power technology = custom
C1E support = disabled
overspeed protection = disabled
Intel C state = disabled
primary plane current = 1024
secondary plane current = 32
EuP 2013 = disabled
CPU phase control = disabled
The new bios now has percentages for vdroop instead of the normal low or auto. I have it at 75% but not sure if I want that percentage higher or lower.
Also when I look at CPU-Z it shows my voltage at 1.320-1.328 idle and 1.232-1.240 during load. The bios shows the same numbers but are no where close to what I have it set at. Is this normal?
Thanks
My current setup
vdroop = 75%
4.2ghz
EIST = disabled
EuP 2013 = disabled
Thanks
