Thats on a Maximus formula, my tester board with very little drop and droop so I get true voltage.
That had some mean memory that doesnt like to work, ocx 4-4-3-15 stuff.
I set everything manually, because all sorts of just have been know to happen if you dont. For instance, if my CPU ratio wasnt manually set to even the default 9, it always reverted my memory and FSB to auto.
The FSB to NB divider just makes it re calculate the final speed for your memory, and can help when it miscalculates the auto setting. Also, lower strap to NB results in better performance Via TRDs data sends.
An easy test to see if you need to adjust the strap is use the f8 to get boot menu, then select anything. If the screen instantly fades away, you are good. if it slugishly fades, you should change the strap to 333, or 400 depending on what one stops it from acting slugish when you select a boot option.
I just wanted to show you that it's not the chip! I have tested VIDs extensively! All got to 3.6 stable.
--Lupi
