Question Need help picking a new motherboard: MSI PRO B760-P WIFI DDR4 or something else?
I would like to upgrade my CPU and motherboard in the upcoming months, and while i haven't yet settled on which exact CPU model i'll get, i'm set on getting a lga 1700 CPU, like an i5-12600k for example. Choosing the CPU is something i can do on my own, but what i'd like feedback on is for the motherboard.
I currently have DDR4 ram at 2666mhz, and the main reason i'm going with this cpu socket and not AMD (since a 7600 is around the same price range as the 12600k for example) is that i can save money by not having to buy DDR5 ram. Knowing that, i went onto pcpartpicker to check the different motherboards compatible with my RAM and the 12600k, and.. I'm not really sure how to find a good motherboard, apart from just checking the top rated one.
I came across the MSI PRO B760-P WIFI DDR4, and it seems to be pretty good: compatible with my RAM, the CPU i want, a good number of USB ports, wifi, bluetooth, not overly expensive... From what I'm seeing, it seems really good, but i'm not sure if there could be potential issues, or if there are any better boards at the same price range.
My criterias are just to have around the same number of USB ports/nvme slots, with wifi and bluetooth support if possible. I do not care for RGB, and the form factor (ATX, micro ATX...) isn't an issue since my case supports all the common ones. Is there anything better out there (that's not way more expensive), or should i just get this model?
Not a bad board for $100.
DDR4 is cheap, so, if you want to go that route, just get a DDR4 3600 or 4000 kit. Running at 2666 will be a big performance hit to 12-14th gen chips.
That said, a 2x8GB DDR5 kit is also quite cheap, though not practical since 2x16GB is the standard size.
Cheaper DDR5 boards are $110.
12700KF is a slightly cheaper than the 12600K at the moment.
PCPartPicker Part List
CPU: Intel Core i7-12700KF 3.6 GHz 12-Core Processor ($174.99 @ Amazon)
Motherboard: ASRock B760M PG Riptide Micro ATX LGA1700 Motherboard ($109.99 @ Amazon)
Memory: Silicon Power XPOWER Zenith Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($79.99 @ Newegg Sellers)
Total: $364.97
Generated by PCPartPicker 2024-12-30 16:30 EST-0500
Reactions: Yamigishi
