Hi,
I recently built a new box with the following parts:
GIGABYTE GA-MA770-UD3 AM2+/AM2 AMD 770 ATX AMD Motherboard
AMD Athlon 64 X2 7750 Kuma 2.7GHz 2 x 512KB L2 Cache 2MB L3 Cache Socket AM2+ 95W Dual-Core black edition Processor
NZXT TEMPEST Crafted Series CS-NT-TEM-B Black Steel / Plastic ATX Mid Tower Computer Case
Rosewill RP550V2-S-SL 550W ATX12V v2.01 SLI Ready Power Supply
G.SKILL 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory
Arctic Silver 5 Thermal Compound
EVGA 128-P1-N309-LX GeForce FX 5200 128MB 64-bit DDR PCI Video Card
When I first started up the machine, it seemed to be working normally. I didn't have a monitor connected, so I couldn't see exactly what was happening. I turned it off and on again once, and it worked.
After that, every time I turn it on, it turns on for a second, and the case lights and fans turn on, and then they all turn off. Then if I push the power button, nothing happens, unless I wait a few minutes first, in which case it once again turns on for a second then turns off.
I thought the PSU was defective, but I RMA'd it and just got the replacement, and I'm still having the same issue. Could someone help me troubleshoot this problem? I'm leaning towards the motherboard being defective, but I'd like to be sure before I RMA another part.
Thanks!
Thanks!
