Need help /w computer upgrade(s) processor etc.
CSwiq
Hi
Unsure about a processor + any other insight is welcome
I purchased a computer awhile back when my old PC just couldn't cut it.
Money was a factor... i wanted something decent ... and cheap that could play games (wow SC2 etc.) with out lag / decent fps
So i got this computer off new egg a few months ago... with plans to upgrade it
My computer --> http://www.newegg.com/Product/Product.aspx?Item=N82E16883229254
so the time to upgrade is here...
Ram upgrade
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML8GX3M2A1600C9B
-Found this with new egg memory finder
Video card upgrade
SAPPHIRE 100338L Radeon HD 6770 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
-cheap decent upgrade
Main reason for post
Processor upgrade
AMD Phenom II X4 970 Black Edition Deneb 3.5GHz Socket AM3 125W Quad-Core Desktop Processor HDZ970FBGMBOX
- http://www.newegg.com/Product/Product.aspx?Item=N82E16819103894
My motherboard: M4N68T-M v2
http://www.asus.com/Motherboards/AMD_AM3/M4N68TM_V2/#CPUS
so i check the CPU support list (above)
i see this on the list
Phenom IIX4 970 (HDZ970FBK4DGM),3.5GHz,125W,rev.C3,SocketAM3,Quad-Core
Same specs... but the
model numbers don't match
HDZ970FBGMBOX
vs
HDZ970FBK4DGM
Edit#2- http://www.cpu-upgrade.com/mb-ASUS/M4N68T-M_V2.html ( this website has both numbers... but its not the Asus site...)
i went to cross check others from the list and they did not show up on newegg
My question is will this processor work or do i need to keep looking...
any other info you feel will be helpful would be greatly appreciated
thanks for your time
Edit- Do the heatsinks come with thermal paste or do i need to buy it
Edit#3- New egg power supply calculator says il be @ 461w( with upgrades) i have 500w power supply... good? or should i look into a new power supply as well
You might be ok on the ps. Depends on who makes it for cyberpower. If you don't want to overclock, try your old board first; no point in getting a premium board if you don't use it's features. All new heatsinks that I've bought have come with thermal paste or a pad (retail box cpus). Keep some $$ handy in case you need to replace the ps for an antec, corsair, seasonic, or ocz ps. I use ocz, and it's ok for moderate use.
9_breaker
865
19
the processor is compatible . however instead of upgrading the processor you could overclock the CPU with a 212 plus and then get a 6950. what's your budget
CSwiq
i did some more research after i posted found some info i was looking for Opn tray / opn pib codes
@ o1die thanks for the info about the thermal paste
i am going to upgrade my ps
i checked http://extreme.outervision.com/psucalculatorlite.jsp
going to be very close + im not done /w upgrades going to do more as needed so might as well get my ps up to speed now
@ 9_Breaker "the processor is compatible" well i did some more searching and it looks to be compatible... seeing your post has brought me some peace of mind
Similar threads
