Need help with a asus p5n32-e sli plus + E6750
cmdixon01
These are my components that I have E6750, p5n32-e sli plus, OCZ DDR2 PC2-6400 Reaper HPC 2GB Edition x2, cooler master 550 watt power supply, 2x Seagate sata 150 gig hard drives, and DVD r-w. My problem is I can’t over clock this thing at all I have read countless things to try on the internet but no luck. All I want is to get 3.2 GHz out of the CPU. I have tried over clocking it many different ways. I can get it to boot into vista it loads everything up then locks up. Some one please help I need to know what to do next I know this motherboard is not the greatest but replacing it is not something that I want to do at the moment. I think it is something to do with the memory but I don’t know I would be willing to replace it. I’m also interested in get some SLI memory what do you think that would do for it?
nah
I run same mobo with a E6850 @ 3.6ghz Mem is sync for 400fsb = 800 mem and 1600 cpu. in you bios to OC you set the FSB but to 1600 (for the 400 "base" fsb) to have my 3.6ghz with 9x as multiplier. Use 8x for 3.2 ...
you alsop have to add some V to the cpu in order to reach it.
hey, just one thing, if you use the 10% or 15% oc from the board what happen ?
From stock to those 15% with those fast setting my system boot, but not with the 20%, have to manual few things, best is to manual EVERYTING ...
It's a great freaking board, I've tested them extensively. It uses the same PCB as the Striker Extreme, which was also a great freaking board.
Your memory on the other hand, could use help. You should try dropping your memory speed first, and set it to 2.00 volts (or slightly higher).
Set your CPU to 1.45 volts, that should give it pleanty of room to OC without making too much heat
Set your FSB termination (VTT) to 1.45 volts
Set your Northbridge (SPP) to 1.50 volts
Set your DRAM to linked mode synchronous
Set your FSB to 400MHz
Love your 3.60GHz FSB-1600 system.
