[SOLVED] Need help with Blue Screen of Death
Errend
28
Hello,
Recently I've been experiencing recurring Blue Screens of Death with my laptop computer which is less than 2 years old. I get Blue Screened at any time - using the computer, starting up the computer, while the computer is sitting idle, or even shutting down the computer. I thought I had a previous state to restore the computer to, but after looking I found I did not have one before the problems began. I've had various error codes on the Blue Screen, which are:
"System Service Exception"
"Critical Process Died" (get this a lot)
"Kernel Data inpage error"
"Bad System Config Info"
"0xc000021a"
"Unexpected Store Exception"
"Memory Management"
"Process1 Initialization Failed"
I've tried several things to fix the problem, which haven't resulted in a solution. What I've done so far:
Updated Drivers
Resetting BIOS
Windows Memory Diagnostic - No errors found
CHKDSK on C & D drives - No errors found
Full Virus Scan - No viruses found
SFScan - Results said errors had been found and repaired, but no effect on continual Blue Screen.
Did a Windows 10 reset (keeping files)
Since doing all that, if anything the blue screen crashes are getting more numerous, to the point I feel lucky being able to post this. At this point I am expecting the computer to spontaneously burst into flames.
Please advise on what would I should do to solve the issue - or recommend your favorite brand of Marshmellows to roast over flaming hardware. Thank you for your time.
Here's some information about my computer (not sure what's needed, let me know if more information required):
PC Make and Model - MSI GL63 8RC
Processor - Intel Core i5 8300H @ 2.30GHz
Motherboard - Micro-Star International Co. Ltd. MS-16P6 (U3E1)
Memory / RAM - 8.00GB Single-Channel Unknown @ 1330MHz (19-19-19-43)
Graphics Card / GPU - Intel UHD Graphics 630/NVIDIA GeForce GTX 1050
Hard Drive - 931GB Seagate ST1000LM049-2GH172 (SATA (SSD))
Optical Drive - No optical disk drives
Operating System (OS) - Windows 10 Home 64-bit
Monitor - Generic PnP Monitor (1920x1080@60Hz)
Thanks for all the help. No blue screen crashes since the clean install; there may be trouble down the line but for now hopefully that means the issue is resolved. Not sure if that means the thread should be closed. If there's more blue screen problems in the future I can create another thread. And I'll start a new thread regarding the issue with the file names.
Reactions: Colif
