Need help with broken 1080ti chip
biggie504
Hey, my friend give me his 1080ti for free to keep if I can fix it.:bounce:
I don't know how he chipped the pins on top of gpu
I was wondering if it fixable to solder it.
Msi 1080ti amor
This how 1080ti the gpu look-nonbroken
This is the broken one, that is mine
those are micro capacitors. a highly skilled electronics repair person with the right equipment could fix it but without even them knowing the correct values of the actual capacitors it prob wont work right.
the repair is just not worth it vs the cost
sorry to be the bad news
Hi, the problem may not be there. Is your friend completely sure that he break that caps? Usually you will see damage on the pads when caps are taken off and is common see empty spaces in some of the caps around GPU
I disagree with max, on high end GPUs as a 1080ti you could pay 300€ for of troubleshooting of a technician or engineer and have it running again for less than 1/3 of the cost. I agree that fix GPUs wasn't worthy in the past or in "cheap" cards and some times they are unfixable but I score a gtx480 back in the day that only needed a new fuse.
If you still have the card around i can try to fix it.
