Need help with cables
DougEFresh
123
I'm looking for some ribbon cable that's in a dell dimension 8400 i have. The cable I want is about 1.5" wide and connects the I/O USB audio panel to the mother board on the front panel connector. See: http://support.dell.com/support/edocs/systems/dim8400/SM/techov.htm#wp1060221
The other cable I'm looking for is thinner and connects the on off button on the front to the I/O panel. Any ideas what type of cables these are and where I can get them?
I took a look at the diagrams in the manual you linked to.
There is a front panel connector on the motherboard between the SATA connectors and the battery. Any chance that connector has two rows of small pins?
Same question for the front audio panel connector. Does it have two rows of small pins?
