[SOLVED] need help with fans
theridechannel98
so basically i bought an a320m mother board. all well and good. but i have a corsair spec delta rgb case that has a fan splitter which requires me to plug it into a 4 pin 12v connection which the motherboard i have doesnt have. there are only 2 places on the mother board where i can plug fans into, the system fan and the cpu fan. is there an cable or component i can buy which allows me to plug the system fan and the splitter into the same port. Thank you
