Question Need help with my XFX Rx 570 8gb
Jul 3, 2023
Hello, so recently I bought Rx 570, and it's been nearly 1 month since then, but recently I don't know why when running superposition benchmark or a game I don't get the fps which I am suppose to get, I get less than half the fps, and in superposition I saw the gpu going crazily up and down the vram, temp and utilization everything was going from lowest to highest like a graph up and down and after sometimes the PC shuts down itself so what is the actual problem causing it?
My spec
I5 4570
H81m-ds21
16gb ddr3 1600mhz ram
(I am pretty sure there isn't any problem with bottleneck as it ran perfectly fine for a month)
You mean you purchased it used, correct? What GPU were you on prior to the RX570?
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. Include the BIOS version for your motherboard as well.
