Need help with PSU
G
Guest
Guest
Hey im going to be doing my first ever gaming build and i dont know what psu I would need for the parts I have chose
CPU: i5 2500k - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&cm_re=i5_2500k-_-19-115-072-_-Product
MoBo: ASRock Z68 Extreme 4 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157250&Tpk=ASRock
GPU: MSI Twin Frozr II GTX 560ti http://www.newegg.com/Product/Product.aspx?Item=N82E16814127594&cm_re=twin_frozr_560_ti-_-14-127-594-_-Product
So yeah if anyone could suggest a good power supply or even the wattage I would need, and also is the GPU okay? Or could anyone suggest a better one at around the same price
I hope that what you said is not exactly what you mean.
I can afford to put 1200 watt PSU's in all my computers - even the ones pulling 300 - 350 watts out of the PSU.
That doesn't mean that I am going to.
