Hi guys,
As the title says I need some help with upgrading my system.
My current system:
CPU: i7-6700K
GPU: Gigabyte Aorus 1080Ti Extreme
RAM: 48 GB (2x8 + 2x16) 2666MHz Kingston HyperX Fury
Motherboard: Gigabyte Z170-HD3P-CF
Case: beQuiet! Dark Base Pro 900
PSU: Cooler Master 750W (Don't Know the exact model)
Main SSD: Samsung 850 EVO M.2 500GB
Monitors: 2x Dell 60Hz 1440p 16:9
So what I want to do is upgrade to AMDs new 5000 series, 5900X to be exact as this one's the best bang for the buck in my opinion.
What I'm afraid of is not knowing what Motherboard I should pair this one up with. I was thinking ASUS ROG Crosshair VIII Formula which is not a cheap one at all.
Also, I'm not sure if I should get a newer one, one that's been made for the 5000 series particularly.
For now, I've chosen this particular Motherboard because of its IO, mostly the number of USB 3 ports, and because of its good reviews.
Another problem is the RAM. I read that the 5000 series are strongly dependant on the RAM so I would be grateful if anyone could recommend me something good, but not over the top since I have a limited budget, but I do need to have at least 32GB.
Last but not least, I need to know if my PSU is good enough. I check the power demand of my current CPU which is 91W and 5900 is 105W.
That's a really small difference but I still want someone who knows more than me to confirm it (not by comparing only the CPU, but the whole configuration.
I mainly use this PC for 3D applications, files management, Adobe Photoshop, After FX, Premiere, DaVinci Resolve, and occasionally gaming.
Thanks in advance!!!
P.S: I apologize if this thread is placed in the wrong category, I'm not really sure where it should be
My current system:
CPU: i7-6700K
