I am trying to help fix a friends computer, but cannot find a solution to her issue. The error began with the system booting to a Windows Error Recovery which states the "Windows failed to start." A recent hardware or software change might be the cause." I am presented with two options: (1) "Launch Startup Repair," and (2) "Start Windows Normally." Both result in Windows beginning to load with a loading bar at the bottom of the screen, before the entire display goes black for ~30 seconds; after which, a mouse cursor appears on the black screen but no action can be taken beyond moving the cursor.
I have tried various solutions which I will explain to help narrow the focus and eliminate options.
I knew this error was most often associated with the HDD or RAM, so I went into the BIOS to first make sure they were both still being recognized and they were. I was then able to run a test on the RAM which came back clean.
I could NOT boot into safe mode and would get the same results as the options mentioned above. However, by pushing F8 I was able to get the additional options along with boot to safe mode which allowed me to disable automatic restart on system failure. This led to the blue screen of death and the unmountable_boot_volume error.
After looking up the unmountable boot volume error, I found numerous articles which said to run the repair disk. This produced the same results as the built in system repair either automatically, or with input commands; however, once I select the repair option, the computer attempts to boot, and fails in the same manner as before.
Overall, I believe it is a HDD issue. I am unsure if this issue can be solved from the software end or if the HDD needs to be replaced completely. Does anyone have any suggestions to try and fix this issue. Keep in mind that I cannot boot into the OS, so any solution must be able to boot from the disc.
