Question NEED HELP
Omar1015
BANNED
Nov 2, 2014
28
my motherboard :
The blue square with “asrock” on it popping out a little more than slightly. I don’t even know what it is. Is this messing up my pc ?
What do you mean popping out a little more? Its got push lock pins and should not move up down left or right, Unless one snapped?
That block is your South bridge, look at the following image.
Of course different factors change with newer architectures, But the base functionality of the Southbridge has largely stayed the same as its a solid method.
So it could cause issue if the heatsink is slightly detached.
its popping out slightly, the push pin wont stay attached to the motherboard
Latest posts
